![]() | Home > Technical > FRONT HEATED GLASS |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
i want to change my front window screen to heated one.
i find that the switch is YUG000460LNF. is it needed and wiring loom or is existed as at Disco 2. if no, can you tell me the part number? thanks www.newfoundland.gr |
I think all the wiring is already there Russell
2011MY 110 XS USW Black |
I stand corrected ![]() 2011MY 110 XS USW Black |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
For the windscreen in my 110DC I used the redundant wiring for the heated rear screen, so have the light up switch, and the dash warning light, but no auto off relay. Still excellent, as it only takes a minute or so to clear.
There are choices of colours for the screen itself - green or clear - I went clear. 2001 TD5 110 DCPU in Bonatti Grey |
Yeah I wonder why they didn't put an auto off switch in the rear screen like they used for the front, I normally keep an eye on the lights and turn the rear screen off as so as I notice the front one has turned off ![]() 2011MY 110 XS USW Black |
i am asking about part number cause if there is no p.num., wiring loom is existed www.newfoundland.gr
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
If the heated windscreen is not fitted from the factory, its extremely unlikley that the wiring will be present. Where fitted, its part of the main wiring loom, not a separate part.
LR seem to have gone away from the "one size fits all" philosophy. Microcat lists 40 different main loom assemblies for the 2007 Defender ![]() Last edited by Fifth Horseman on 23rd Dec 2011 7:21pm. Edited 1 time in total |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Make sure you buy a genuine land rover screen. The britpart ones have a hiddeous silver strip at the top and bottom, and use a bazarre three wire arrangement!
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Use www.heatedwindscreens.com
And the problem with 3 wires is..? |
There are no wiring instructions with the britpart screens, just three thick wires with no connectors fitted. Connect the original connectors to the screen, and it won't work. There's that mysterious stray wire in the middle. ![]() Looks hideous with the silver strips, so use original equipment instead, which has the correct spade connectors on each side. |
yes, it is ok.
but if it is needed another main loom just for one heated glass, you have to sell one of your ..........kidney ![]() it must be something else.................... there is p.n. of screen(LR009821) there is p.n. of switch(YUG000460LNF) where is the loom?????? ![]() ![]() (of course we are talking about genuine land rover screen) www.newfoundland.gr |
