Home > Series Land Rovers > Yep another oil question.
spudfan
Ireland
Has anyone used 10w-40 semi synthetic in a series 111 with the 2.25 diesel engine? I have always used 15w-40 mineral oil but with the last cold spell I was wondering if the 10w-40 semi synthetic might be better for those first cranks on very cold days. No difference in the price for the oil. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #982067 11th Feb 2023 3:01pm
MK
as it has flat tappets, make sure the ZDDP is above 1000 ppm (So API CI4). 15w40 is suitable down to -25C and 10w40, down to -30C. Puma 110" SW
Post #999844 13th Jul 2023 12:44am
TexasRover
Does the 2.25 diesel have flat tappets? The petrol does not. Still high zinc content is going to be beneficial as an additive.
Post #999848 13th Jul 2023 5:39am
Dinnu
On my 19J engine (which is not much different than your 10J), I always used 15W40 mineral oil.
But for my old VW diesel, I have always used 10W40 semi synthetic and that thing has lasted.
So I have decided to use 10W40 on the 19J, but still have to see long term (I only started it for a couple of seconds since the engine rebuild - but even so, what is long term on a vehicle with occasional use?).
Mind that the ambient temperature here is a bit higher than at your location. Winters can go to about 10dC, summer will be mid 30s. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999849 13th Jul 2023 5:50am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Shouldn't that be 20W50 according to the manual? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #999856 13th Jul 2023 7:15am
spudfan
Ireland
I did top up with 10w-40 semi synthetic but it seemed to clog the breather filter on top of the engine, so I just use 15w-40 mineral. I used to use 20w-50 but the handbook says that 15w-40 can be used. I just use the basic stuff and all is well. 1982 88" 2.25 diesel
Post #999925 13th Jul 2023 3:26pm
Dinnu
The handbook for a series 3 Land Rover was probably written based on oil technology from the 60s or possibly earlier. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999926 13th Jul 2023 3:28pm
spudfan
Ireland
I agree as the specs listed for the oil have long been superceded. 1982 88" 2.25 diesel
Post #999927 13th Jul 2023 3:29pm
MK
The owner manual 2.25 santana diesel on a SIII recommended 10W40 api CC. Neither CD, nor above.
Post #999948 13th Jul 2023 5:47pm
spudfan
Ireland
I am currently using Valvoline which has a CF classification. Very difficult to get anything with a lower rating.
CD Obsolete CAUTION: Not suitable for use in most diesel-powered automotive engines built after 1994.
CC Obsolete CAUTION: Not suitable for use in most diesel-powered engines built after 1990
CF Obsolete CAUTION: Not suitable for use in most diesel-powered automotive engines built after 2009. Later “C” category oils are usually suitable or preferred for diesel automotive engines for which “CF” oils were specified. Older equipment and/or two-stroke diesel engines, especially those calling for monograde products, may however require “CF” category oil 1982 88" 2.25 diesel
Post #999963 13th Jul 2023 7:10pm
MK
I would contact Morris Lubricants or westway. I guess they now their science. Puma 110" SW
Post #1000013 13th Jul 2023 10:39pm
spudfan
Ireland
I have checked both Morris and Westway and their mineral 15w-40 is to a higher spec than CC/CD spec . 1982 88" 2.25 diesel
Post #1000019 13th Jul 2023 11:06pm
MK
One carries 40 monograde CC and the other 10W40 CC.
Back in those days our SIII used Ursa monograde 40 api CC all year round from -5 up to over 30C. Puma 110" SW
Post #1000022 13th Jul 2023 11:13pm
