![]() | Home > Puma (Tdci) > fuel tank draining |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17787 ![]() ![]() ![]() |
How much is in the tank?
If less than half full, lower the tank as is. If more than half full, syphon it via the filler. No need for a pump. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 747 ![]() ![]() |
I dropped my tank recently to fit an aux fuel line for a Chinese diesel heater..
I ran the tank to under a 1/4 and then removed the rubber section of pipe between the lockable filler and the plastic tank.. Once that's off its easy to get a hose into the tank and syphon what's left into a container.. ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6669 ![]() ![]() ![]() |
Doing it on a 110 is very different to a 90.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Ain’t that the truth
![]() I only ever get them when they’ve tanked them because it would start too! |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 260 ![]() ![]() ![]() |
Driven it until the warning light has come on. if it wont piddle out the filler pipe hole then i will have a go as is. 1953 80" 1987 mini city e 2011 90" |
A bag and some duct tape over the end will minimise spillage.
If the light's on fuel will only come out if you tilt the tank a lot getting it out. It won't even make it unmanageably heavy.
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3402 ![]() ![]() |
Off the original topic but wondering if you considered one of these for the fuel pickup before dropping the tank? Takes 15 minutes to fit in the filler neck. ![]() Click image to enlarge ![]() |
He’s replacing the cracked/perished breather hose.
Yep got that, I was replying to andy63 who was fitting a diesel heater pickup pipe.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8275 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
hi... no not come across that fitting.. how does it fit ...and where do you take the aux fuel line out of the filler tube to connect to the dosing pump for the heater.. I wanted to drop my tank anyway to apply some body protection.. as it happens the sender unit on the tank has an aux off take pipe on it, so I didn't have to use the dip tube I had from previous work on a motorhome.. ill see if I can find the photo.. |
![]() Click image to enlarge That's the photo of the sender unit /pump with the aux off take and the dip tube that I didn't have to use👍 |
You cut the rubber filler neck pipe in half and insert the unit in before fastening it back up with a pair of jubilee clips. The pick up pipe then dips into the tank.
