![]() | Home > Puma (Tdci) > TD4-oilsump without "dent" |
Dutch Member Since: 06 Jun 2016 Location: Bavaria Posts: 7 ![]() ![]() ![]() |
Hi All,
my 2 year old oilsump (genuine) is already very rusty again. Lots of salt, snow, rain and dirt on our roads do their job well. The miserable quality of steel helps also ![]() In the course of a nuts & bolt restoration (ongoing project), I partially overhauled the motor and put him back to where he belongs. I then donated a new oilsump (LR007598) from Autodoc and received a VAICO-sump without the big “dent” in it. See pics. Between the front propshaft and the oilsump is still around 10-12cm space. N.B.: Springs and shocks are new. Is this “dent” a must have -means only Genuine LR-Part- or will there never be contact between propshaft and oilsump to be feared? Why is this dent in the genuine sump? Thanks in advance Ron ![]() Click image to enlarge ![]() Click image to enlarge |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2425 ![]() ![]() |
See second post down from blackwolf https://www.defender2.net/forum/topic74975...t=sump+pan.
Unfortunately Your new one is not suitable , you need one like your original. Also you don’t need a genuine LR one, plenty of correct shaped aftermarket ones on the net. |
Hi MK & IanH,
thanks you both for answering. I just ordered a genuine pan and will 2k-paint it immediatly. BTW not only for removing the pan and seals, Mikes tool* is very usefull. I used it all the time while taking apart the good ol' rusty 07 ![]() Cheers Ron *=britrest-dot-com/product/dismantling-tool |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
When I replaced my sump, I gave it a quick rub down and sprayed it with Buzzweld CIO, that was a few years ago and its still mint now.
This thread has reminded me, I replaced mine with a Bearmach one I don't know if it had the all important dent or not.... Must check 2007 110 TDCi Station Wagon XS |
