![]() | Home > Maintenance & Modifications > Headlight adjustment |
Hi all
![]() Thanks to excellent advice from you lot, I bought some Philips Extreme Vision bulbs and fitted them with Crystal headlamps from Paddocks (ridiculously fast postage to Germany ![]() Considering my 110 now lights up the road like "Crystal" Palace ![]() I've done this on a 1974 Beetle where the dipped beam setting on a wall is (centre of brightest area) 5cm below bulb height at 5 metres. Trouble is, the lights on the 110 are almost twice as high ![]() So... please can anyone tell me a "rule of thumb" for setting the headlights? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Personally I'd have marked the beam on the wall with the vehicle positioned a know distance from it prior to doing anything - then you would have had some reference points to work to. As it is the best way would be to get them properly set up on a proper headlamp aligner. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
NOW you tell me ![]() Actually I'm fairly sure they weren't well set to start with - probably part of the reason they seemed so pathetic. I will get them set properly a.s.a.p. but the nearest TÜV is in Munich and it will be a week or more before I can get an appointment... Cheers Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
doesn't your defender have adjustable headlights? |
er... if you mean the compensation dial on the dash, then yes but only down.
I adjusted them to be level today (with a screwdriver ![]() Good idea though ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
You're not going to be far wrong applying the same principle to a Defender. The difference in height between it and a Beetle is an insignificant proportion of your 5m test distance. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Cheers ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
I just adjust mine to give me a nice 'spread' and then go for a drive.
If i get a flash or two from oncoming traffic i re adjust height and try again. Keep doing until no-one oncoming seems bothered ![]() |
Good - seems pretty much what I thought ![]() Cheers Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
As ZeDefender says,but with a picturefrom the workshop manual.
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Don't know if I'm bonkers but my trimmer screws are at the bottom
![]() If I had fitted them the way they are in the picture, the towing adjustment would make them aim higher ![]() Change in design? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Could well be. I took the diagram from a tdi manual to illustrate the wall settings. 1982 88" 2.25 diesel
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
my question is what is the mesurment of a and b Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
As far as I know it should be the same as on the vehicle. Any garage with light checking equipment will check them and adjust them if necessary for a small fee.I get mine done before a vehicle test. 1982 88" 2.25 diesel
