![]() | Home > Puma (Tdci) > How to stop the wipers when squirting the windscreen?? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18045
It's much easier to bend the spade pin of the relay at 90° (or even cut it off) so it doesn't enter the relay socket than it is to mess about with the socket.
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
You're probably right blackwolf. I have a .99 relay somewhere anyway, so I think I'll give it a try cutting off the pin.
I just folded the pin flat against the base of the relay, easier than cutting. It is literally a sub-sixty-second modification and a huge improvement.
Thanks for pointing out the simplest solution
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Which pin did you remove BW From this wiper relay? Click image to enlarge |
It's the one that industry calls "T", Land-Rover calls C0303R-6, and is the one in the top right of your photo.
If you just bend it flat it will have the same effect, can't touch anything, but (probably) allows you to change your mine at least once. |
| All times are GMT |
