Home > Maintenance & Modifications > stealth camping mode - disable horn, CDL flashing
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Two small and easy modifications to make camping with the Landy a less embarrassing experience Embarassed
1. I keep accidentially pressing the horn button whilst rummaging around on the (LHD) driver's side. So I installed a switch that disables the horn button on the stalk (only). Easiest and reversible way I found was to (mis)use a fuse tap off. Instead of the second fuse I inserted spade connectors wired to the switch.
2. There are situations where I don't want the indicators to flash with un/locking the doors. I inserted a switch into the indicator power supply to the ALM. Due to the limited space and stiff wiring loom of the ALM I found it difficult to crimp in wires for a switch. I went for Wago clamps instead. Others have good long time experience with them, so I keep fingers crossed.
Post #999200 8th Jul 2023 2:27pm
geobloke
Good job Thumbs Up It does make stealth camping a little challenging when the indicators are capable of lighting up half a hillside Rolling with laughter
Post #999204 8th Jul 2023 3:00pm
The indicator flash is really easy to turn off (or reconfigure) simply by changing a setting in the 10AS if you have a diagnostic tool.
Post #999207 8th Jul 2023 3:34pm
geobloke
Blimey Shocked I confess I never knew that... Bow down
Post #999209 8th Jul 2023 3:35pm
macfrank
Yes. I don't want to have it permanently off. Just now and then.
Post #999214 8th Jul 2023 4:06pm
