![]() | Home > In Car Electronics > Relay |
| keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 186
2007 2.4 Puma
Is there a separate relay for the rear wiper motor and if so where is it. Keith |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Yes, mounted to the rear door behind the panel, C0124 in the photo below.
Click image to enlarge |
Thanks, I'll investigate tomorrow
Rear wiper not working.
Just an update which may be helpful to others. Located the relay as per Blackwolf. It wasn't clicking when the rear wiper switch was switched on. Found a little test in the archives when doing a search (courtesy of Martin). Put a temporary wire from the Green/Black on the relay to known earth and, in my case, it clicked. This wire is a switched earth to the relay. Traced the fault to broken Green/Black wire in the usual place, inside the rubber sleeve to the back door, where it is constantly being deformed by the opening and closing. New length of wire soldered/sleeved, all good |
