![]() | Home > Puma (Tdci) > Rear door not opening |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
I am in the same boat. I suspect the internals need dismantling. Puma 110" SW
| drivetrainshunt Member Since: 27 May 2023 Location: Surrey Posts: 13
I’ve just been out and done a little bit of investigation. It opens fine from the inside. Guessing it is whatever the outer handle attaches to, it’s just not quite moving things enough.
Is there a known easy repair for this? Assuming if I disassemble the mechanism, I might be able to put thing a back in the right place? |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Is the child lock accidentally activated? 1982 88" 2.25 diesel
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Child locks work the other way around, i.e. stops it being opened from the inside. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 9th Jul 2023 4:54pm. Edited 1 time in total |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
Maybe same issue as this: https://www.defender2.net/forum/topic86427.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Worth squirting a bit of lube inside it, they just get tired and worn out though.
Tried stripping apart, cleaning and lubricating. Rear handle still not providing enough movement to fully disengage latch.
Ordered new part from Masa 4x4. They’re not super speedy are they! |
