Home > Maintenance & Modifications > Webasto sunroof
Poulstonb
Webasto sunroof
Evening all
As expected my sunroof leaks.
It’s currently siliconed shut. Thinking of changing it for a new one or even a double glazed unit as I never open it as I have air con.
Do you think it’s factory installed or aftermarket .
Is there anyway of finding the build sheet for the car ?
Post #997635 26th Jun 2023 9:16pm
geobloke
Photos please?
Post #997663 27th Jun 2023 8:05am
Poulstonb
Post #997775 27th Jun 2023 6:12pm
ickle
It looks very similar to one that was fitted to my 100".
Lift the glass out and clean the seal really well, if the front two 'tongues' unscrew from the glass remove them, flatten them a very small amount to increase the pressure on the rubber, put a thin smear of vaseline on the rubber and refit and test.
If you open it you will have to remember to clean and regrease the seal periodically.
HTH Keith
Post #997790 27th Jun 2023 8:46pm
Poulstonb
I’ve tried resealing it which between metal and frame is fine but water gets between glass and rubber . Tried cleaning and greasing to no avail.
Want to either replace with same or a double glazed option.
Post #997791 27th Jun 2023 8:49pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I've always had positive results using silicone pipe grease on the rubber gasket
Post #998295 2nd Jul 2023 5:58pm
geobloke
It would be worth contacting someone like https://www.bristolsunroofs.co.uk/index.php as they will be able to direct you a bit better.
Post #998345 3rd Jul 2023 9:37am
Poulstonb
Tried the phone number but not working . Does anyone know if they’re still open ?
Post #998458 3rd Jul 2023 8:16pm
Poulstonb
Struggling to find anything to repair or replace the sunroof so gone for a double glazed unit from vehicle Glazing Specialist.
Hole size is slightly bigger so will need to do some nibbling
Wish me luck
Post #998492 4th Jul 2023 7:24am
Poulstonb
Installed the double glazed unit from VGS
Looks great.
Glazing silicone supplied was awful stuff to use but did the trick
Post #1002623 1st Aug 2023 10:19pm
