Home > Technical > Unidentified unused connectors behind headlight?
murph81
Ireland 2007 Defender 110 Td5 PU Belize Green
Can anyone help me identify these connectors I found while replacing my headlight rings.
One of them is the same type of connector as the indicator and parking light so I'm hoping it's spotlight related as I'm hoping to fit a pair.
It's a 2005 TD5 single cab pickup, not sure what spec, nothing fancy on it.
Post #996401 15th Jun 2023 5:33pm
rallysteve
Left to right, optional extra horn for alarm, battery backed-up alarm sounder and headlight levelling.
Post #996409 15th Jun 2023 7:51pm
murph81
Great stuff, thanks Steve!
Post #996413 15th Jun 2023 8:08pm
tommac
United Kingdom 2001 Defender 110 Td5 DCPU Alveston Red
Great stuff Steve- you’ve solved a query I had- I have 2 of these floating around behind the headlight- couldn’t work out what they were for! How many defenders have levelling headlights!?
Post #996598 17th Jun 2023 11:05am
Loads, any with XS spec probably will.
Post #996609 17th Jun 2023 1:37pm
tommac
Ah- fair!
Post #996653 17th Jun 2023 8:15pm
the_lincs_landies
LR Workshop has a good electrics section, including a “connector by wire colour” which has helped me identify unused connectors no end of times
Post #996679 17th Jun 2023 11:47pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
I believe that headlight levelling came standard on County Station Wagons after 1997?
Jim
Post #996722 18th Jun 2023 11:23am
Quite likely, although not fitted to County-spec variants of "commercial" models.such as the DC, which "benefitted" from the hopeless and stupid dim-dip system.
Post #996726 18th Jun 2023 11:51am
TexasRover
I had a 1999 CSW which did not have it.
I have had (different) cars with and without and can't see it's all that valuable. I think I had a D2 which had adjustable headlights AND rear air suspension, I mean, really....?
With modern lighting as it is, most people have accepted that occasionally you will be completely blinded by oncoming traffic.
Post #996730 18th Jun 2023 12:16pm
90 Dreamer
Far worse and dangerous now that we seem to have entered the twilight zone in terms of modern vehicle lighting......
Why should it simply be accepted??
Post #996731 18th Jun 2023 1:12pm
tommac
Thanks @the lincs Landy- will take a look!
Post #996779 18th Jun 2023 8:10pm
