Home > Puma (Tdci) > Axle oil in the hub
DOUG MALGARIN
United Kingdom 2009 Defender 110 Puma 2.4 USW Zermatt Silver
Axle oil in the hub
MY110 rear axl oil in the hub i think the seal in the stub axle has gone , How hardis it to repair ?,
Post #996207 14th Jun 2023 7:18am
TexasRover
It is not a problem to have (differential) oil in the wheel bearings as long as the seal at the back of the hub is not passing oil (onto the brake disk).
To change the oil seals you have to disassemble and remove the sub axle (few bolts). Easy job but a bit messy.
Post #996225 14th Jun 2023 10:04am
Mother superior
Yeah, it's a pretty easy gig. There's a small seal within the stub axle and two larger ones in the hub assy.
I got my bits from Advanced factors and would also advise you to use a drip tray of some sort.
Be super vigilant for any contamination of the braking components but other than that, have fun, it's a nice old school nuts and bolts job, but don't forget to order new drive flange gaskets as well!
Wes Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #996234 14th Jun 2023 11:44am
Many people actually remove that seal in order to obtain better lubrication of the rear wheel bearings. As long as oil is not escaping from the hub to the outside world, and especially via the back of the hub into the brakes, there really is no point doing anything about it.
Post #996244 14th Jun 2023 2:20pm
