Home > For Sale & Wanted > SOLD LR Defender 90 300TDi Auto Soft-Top
Litch
Land Rover Ninety (Defender 90) 300TDi Auto soft-top.
Stunning condition, owned, maintained and upgraded by me regardless of cost since 1999.
Not a recent “rebuild” as such, this has been upgraded over a period of time however it is evident that several major components are very recent and the whole vehicle is incredibly straight, clean, tidy and mechanically excellent having been regularly and meticulously serviced.
I have all MOT’s since release in 1999, demob paperwork and two box-files of receipts as well as a year by year pictorial history including the annual agreed valuation photographs.
Truck Utility Light FFR Hardtop 12/24V 4x4 Land Rover 90 Diesel. Mod Reg 76KF86.
Date into service 11th July 1986.
Cast to British Car Auctions (Somerset) 1st Dec 1998, mileage 93,687KM.
Bought March 1st 1999. Mileage 94,082KM and registered by me as C*****. 1st owner on logbook.
Second-hand (MPH) speedometer fitted July 1999.
Original (KPH) speedometer reading 95,244KM, replacement (MPH) speedometer reading 43,511M with all subsequent readings taken from this.
2000. Mileage 46,325M. Brand new body fitted, bare-metal painted Coniston green dismantled/off the vehicle, changed to soft-top.
2004. Mileage 64,648M. Brand new 300TDi re-power fit fitted by Buryas Bridge (LR dealer, Penzance).
2013. Mileage 100,337M. Bulkhead galvanised.
2014. Mileage 103,617M. Brand new TDCi bonnet fitted.
2014. Mileage 103,684M. Brand new fully dressed (TD5 spec) front axle fitted.
2015. Mileage 105,129M. Used TDCi rear axle fitted.
2016. Mileage 107,954M. Brand new ZF 4HP22 automatic gearbox conversion fitted (Ashcroft Transmissions).
2017. Mileage 111,138M. Reconditioned 1:41 Transfer Gearbox fitted (Ashcroft Transmissions).
2019. Mileage 118,070M. Brand new galvanised steel front doors fitted (SP4x4).
2020. Mileage 120,014M. Brand new galvanised chassis & ancillaries fitted (Richards) – original chassis leg retained showing chassis number.
2021. Mileage 120,970M. Major service inc cambelt, tensioner, aux belt, tensioner, water-pump replaced.
Based on current mileage of 123,920M (which will move slightly) the major components have covered the following mileages FROM NEW:- Engine 59k miles, front axle 20k miles, auto gearbox 15k miles, chassis 4k miles.
Bodywork. All bodywork replaced with brand-new (with exception of seatbox which is original). Galvanised bulkhead, SP4x4 galvanised steel front doors, X-Trouser door strikers, TDCi bonnet, Defender Peak external sun-visor, galvanised side-hinged tailgate, galvanised battery-box, galvanised capping and ancillary brackets, galvanised Terrafirma rock sliders, anodised billet windscreen blocks. AWT canvas tilt and fume curtain on MOD spec hoops, Trip-Net webbing cargo net above tailgate, galvanised swing-away spare wheel carrier, galvanised door-sills, SS rear threshold. Gwyn Lewis mud shields, flaps (F&R) & galvanised tub brackets. SS fasteners throughout.
Engine and transmission. ROW spec 300TDi, ZF auto geabox, 1:41 transfer-box. Late spec axles. Safari-Snorkel, Demand Engineering SS exhaust on polyurethane hangers, Allisport oil breather tank, Brunel high-flow intercooler (standard shape), T28 spec turbo, galvanised rad frame & brackets, X-Eng X-Cap to rad & thermostat housing.
Fuel. New fuel-tank, pick-up, sender, filler pipe, flexible hose, galvanised mounting bracket.
Chassis. Richards galvanised chassis, primed, painted & Waxoyled. Galvanised bumperettes on rear, Dixon Bate towing ball/pin.
Interior. Monmo 350mm wheel on close fitting adaptor. Exmoor Trim front seats in Techno fabric fitted with LI Upholstery tailored canvas covers, NAS spec auto gearbox console with illuminated shifter and cubbybox, alloy Hi/Low knob. Rear fitted with flat floor covered in ribbed rubber mat, 2 x pull-out storage boxes and under-floor storage.
Brakes. TD5 front axle with vented discs, TDCi disc braked rear axle, new pipework, SS flexible hoses, X-Eng disc handbrake.
Suspension, steering & tyres. Solid steering bars with greasable UJ’s, adjustable A-frame joint, Super-Pro bushes, OME steering damper, Koni HeavyTrack shocks, OE springs (HD on rear), galvanised turrets & spring seats. 265/75x16 Cooper ST MAXX tyres on anthracite Sawtooth wheels (inc unused spare under cover).
Electrics. 100A alternator, fused main battery cables (TDCi mega-fuse), FIA master-switch, Autosparks wiring loom, blade fuse-boxes, LED lighting (Nolden headlights, Le Perei NAS spec rear, Wipac front), Hella Rallye 3000 spot-lights, Raptor binnacle, mount & centre console inc Carling switches, Durite instruments (fuel, engine temp, volts, oil press & clock), thermometer (external temp), CD/radio (4-speakers), LED map-light, cig lighter & USB charger, LED interior light, heated front windscreen, Spafax unbreakable heated mirrors, relay operated headlights, spotlights & horns, recent (brand new genuine) wiper motor and complete heater unit, twin pump/washer windscreen jets.
Cosmetic upgrades. Nakatanenga Herritage grill and headlight surrounds, galvanised front light-guards, Optimill door hinges (F&R), Optimill door handles (with security locks), silver anodised chequer-plate wing tops, front D-rings, Mantec steering guard, rear Jate rings, Offroad Tec SS bonnet hinges, Climair wind deflectors, KBX Hi-Force heater intake vent, MT pattern fold-down rear step, CNC machined badges on bodywork (Land Rover Automatic, Defender 90 Union Jack, Snow Rover & Mud Rover), enamel Union Jack badges.
Security. X-Eng folding pedal-lock, X-Protect column lock, door security hinge-plates. Other devices to be revealed only to buyer.
I cannot overemphasize how clean and corrosion-free this vehicle is!
£20,995. ono
PM me for further information or photos.
 ONE LIFE, GET IT!
Post #995995 12th Jun 2023 2:18pm
Huttopia
Looks cracking but probably needs a price, unless I missed it somewhere Smile. Now there Laughing
Post #995996 12th Jun 2023 2:21pm
Litch
A couple more which I forgot to include.
 ONE LIFE, GET IT!
Post #995997 12th Jun 2023 2:27pm
mini Anaconda
That looks great. Good luck with the sale. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #996005 12th Jun 2023 3:31pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Looks lovely Thumbs Up Thumbs Up
Any photos with the canvas off?
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #996007 12th Jun 2023 3:59pm
That is very clean.. nice
Post #996028 12th Jun 2023 7:38pm
Mo Murphy
It is a fantastic 90, the pictures don't do it any justice at all ! First to see will buy !
50 Shades of Pennine Grey
Post #996048 12th Jun 2023 9:18pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Every time I see this Defender in posts I just think Wow!
Good luck with the sale Litch, though I am sure it will break your heart!
Someone is going to get a real keeper with this!
Post #996068 12th Jun 2023 10:32pm
Litch
Clemmo
I have been looking and don't think I have a single photo with the canvas off other than when I was swinging the rear tub across from the old chassis to the new.
Only ever driven it with no canvas about twice (in 24yrs!) as I can't stand the sun on the top of my head (bald), instead I usually drive with the rear rolled up (hence the cargo net across the open rear) and in really hot weather, with the sides rolled up.
Thanks for the kind words everyone.
Will be sorry to see it go but have owned LR's for over 35yrs (this one for 24yrs) and lack of use means it is now just an indulgence that isn't being used or appreciated.
Last year I covered 801-miles (and that included moving house when there was lots of running around to be done), I bet this year it is unlikely to cover under half that. A new motorcaravan is ordered and scheduled to arrive next Easter time(ish) so I don't need to have the driveway cleared until then, for that reason I am in no urgent rush to sell and have not yet put it on Autotrader but if any interested party said they wanted it then I am obviously willing to let it go now.
I originally intended to hang onto it until I retired (hence why I was happy to replace the chassis etc back in 2020) but I have now (early) retired, moved house and all our other plans have been brought forward by a few years. Very Happy ONE LIFE, GET IT!
Post #996127 13th Jun 2023 2:37pm
Litch
Clemmo
Took some new photos today, none with the canvas completely off but rolled up and how I usually use it in the summer.
 ONE LIFE, GET IT!
Post #998957 6th Jul 2023 8:49pm
LR90XS2011
nice DEFENDER 90 TDCI XS,
Post #998958 6th Jul 2023 8:52pm
Litch
My baby is now sold. Big Cry ONE LIFE, GET IT!
Post #1002112 28th Jul 2023 6:33pm
Screbble
You’ve made someone very happy 😃 👍
Post #1002117 28th Jul 2023 8:19pm
Mossberg
Well done with the sale. I hope who it has gone to appreciates what they have.
I hope you stay on the forums as you are a great contributor.
Post #1002120 28th Jul 2023 9:34pm
Racedriver
United Kingdom 2015 Defender 110 Puma 2.2 USW Indus Silver
How much did you sell for in the end?
Post #1002151 29th Jul 2023 11:38am
