Home > Expedition & Overland > Roof tents
Page 9 of 9 <123456789
the_lincs_landies
Ah ok, I thought I might have missed a trick to be honest, my solution seemed too easy to have been missed.
I think the only way it could work without drilling is if you had a contraption that turned the T tracks in the tent to be width ways so that you can then use standard fixings... as the tent only has on track on each side its going to not be able to be secured. Unless of course, this chap is thinking that you secure the left T Track to the right... :/
Post #995605 8th Jun 2023 4:25pm
CallumB
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Now then.... Idea You might be on to something there. It would raise the height of the tent up more than I really want (already pretty tall) but that might just be it! Thanks @the_lincs_landies Thumbs Up
Post #995618 8th Jun 2023 5:36pm
landy andy
When I had a rack with front to rear bars I drilled through them and bolted direct to the rack. I did, before I got around to drilling the rack, fit three cross beams under the roof tent (Maggi) then clamp them to the beams. Only temporary as wanted the roof tent as low as poss
Post #995625 8th Jun 2023 5:52pm
