Home > Technical > LT77 Gear Selector cover part identification
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Hi, Im hoping someone can help identify a part from my LT77 gearbox.
I have attached an image outline the part i am trying to find.
My gearbox has been making some terrible crunching noises when selecting 1st and sometimes reverse. Was advised to remove the gear selector cover as starting point, see if anything obvious. When I lifted it off, there was a heart-stopping ping - plop noise as the notched bit in the photo fell off into the gear box.
Does anyone know the name or part number for a replacement part.
Thank you
Post #995178 5th Jun 2023 3:57pm
rallysteve
Post #995179 5th Jun 2023 4:10pm
consumerize
Fantastic, Thank you very much
Post #995182 5th Jun 2023 4:43pm
As above, it appears to be UKC3660 and you may want to sit down before you look up the price, if you can even find one. A pre-owned gearbox might be cheaper. Shocked
Post #995185 5th Jun 2023 4:52pm
rallysteve
Post #995188 5th Jun 2023 5:02pm
Dinnu
Perhaps stating the obvious, but is it not better to retrieve the one that you dropped?? Risky to leave it in there. And the screws? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #995231 5th Jun 2023 6:54pm
consumerize
It snapped off. it seems it is just braised on there. looks like brass. The plate and bolts still in place.
I may end up taking the whole box out to sort whatever the problem is (if that wasn't the issue), so will then remove.
It can't get much crunchier in the gears !
Post #995245 5th Jun 2023 8:03pm
Dinnu
I see... looking at the part pictures, it indeed looks like it is made of 2 parts, possibly brazed together. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #995247 5th Jun 2023 8:07pm
