![]() | Home > Puma (Tdci) > Millers xf long life c1 |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
I use it for my 2.2 Puma and change it every 6k very happy, cheapest way to buy it is in the 20 litre container.
![]() Last edited by Def90 on 3rd Jun 2023 7:24pm. Edited 1 time in total |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Makes sense to me!
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
I’ve been using it for the last 7 years. It’s vey good oil for the 2.2 with a DPF and would certainly be good for 12k miles service intervals. (If it’s not been over diluted with diesel via active regens and the oil service message coming up ).
I’ve used many different specification millers oils in many vehicles over many years and every one has kept the engine in very good condition. I change my oil twice a year, which is circa every 3k miles, which is over the top I know. But as I buy in bulk it’s not that expensive. |
Yorkshire lad Member Since: 30 May 2023 Location: East Yorkshire Posts: 30 ![]() ![]() ![]() |
Thanks for the reply guys I'll definitely be using it from now on do they have a good oil to use in the diffs or is it best to use castrol epw transmax 80w90.
Go for
Castrol transmax Axle 'EPX' 80w-90 for the Diffs (until it comes out of filer hole , circa 1.6Litres per Diff) Fuchs 'Titan' race syn 5 for the Transfer box (until comes out of filler hole - circa 2.4L) Castrol 'Syntrans' for the Gearbox, now called TRANSMAX Manual Multivehicle 75W-90 Fully Synthetic Transmission Fluid (2.4 Litres for the Puma 2.2, 2.2 L for the Puma 2.4), Worth getting magnetic drain plugs for diffs and gearbox. Lots of info here https://www.defender2.net/forum/topic8707.html |
Thank you ian I'll get it all ordered from opie oils they seem very well priced.🙂
Opie oils is a site sponsor, DEF2 in the voucher field will get you a 10% discount.
