Home > Puma (Tdci) > Bonnet Release Cable Connector Location
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
A trivial issue but it’s bugging me!
The plastic connector box where the two separate bonnet release cables are joined is floating freely above the wheel arch liner, but I can see it has two locating pegs underneath that I presume allow it to be clipped in somewhere - I can’t see any suitable holes in the arch liner close to where it must go.
Related, not sure if it’s currently installed with the correct routing, e.g. around the arch liner to wing bracket.
Any help appreciated Thumbs Up
Post #994709 1st Jun 2023 9:27am
I think that they all float, I've certainly never seen one that was attached to anything. I suspect that LR bought in a COTS part that has provision for mounting and simply ignored the mounting clips.
Post #994716 1st Jun 2023 10:51am
jcw
Ah, ok - I can tick that off the list then.
Thanks Blackwolf Thumbs Up
Post #994722 1st Jun 2023 1:20pm
Dinnu
I had the same question, as I know that in my Defenders' past, it had the complete right mudguard replaced. So was wondering if everything was 'factory' correct. Thanks for the info. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #994737 1st Jun 2023 4:22pm
