Home > Technical > Brakes
spudfan
Ireland
Brakes
300 tdi problem. Going fine, hit the brakes. Brake pedal hard to push down, car takes longer to stop. Any ideas? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #994460 30th May 2023 10:32am
landy andy
Failed vacuum servo, or the supply to it.
Post #994461 30th May 2023 10:41am
spudfan
Ireland
Yes I thought it was servo related but any thing I can check...I am doing this over the phone to my daughter! 1982 88" 2.25 diesel
Post #994462 30th May 2023 10:43am
TexasRover
Engine off. Pump brakes few times till hard. Keep foot on brake and push then start engine. Pedal should sink as the vacuum assist start assisting.
Post #994463 30th May 2023 10:47am
spudfan
Ireland
Thanks. Her phone is engaged, I'll pass that on when I get through. 1982 88" 2.25 diesel
Post #994468 30th May 2023 10:52am
landy andy
After the engine has been running you can pull the vac pipe out of the servo and you should hear a very big hiss, as vacuum is released. Also whilst vac pipe is out, start engine and you should be able to feel the vacuum, when you put finger over end of pipe.
It could be failed servo (often crack), it could be failed vacuuming pump, or it could be failed vacuum pipe, or the T or pipe that is in the pipe that goes to the EGR depending on model.
Post #994470 30th May 2023 11:25am
spudfan
Ireland
I presume it is like braking on a series 111 now! Can't get her on the phone. I'd say she could drive safely just give herself extra stopping distance until it is sorted. 1982 88" 2.25 diesel
Post #994471 30th May 2023 11:30am
landy andy
It will be worse than a series, as the newer system was designed to be assisted, older wasn’t. I wouldn’t recommend driving it if it was my wife (I don’t have a daughter) Thumbs Up
Post #994475 30th May 2023 11:57am
spudfan
Ireland
Just got a message to say that she got home, slowly but safely. I told her to check the hose going from the servo to the engine. It happened so quickly it sounds like the hose came off at one end. I will update when this is sorted as to what the problem was.
Thank you for all who gave advice. Thumbs Up 1982 88" 2.25 diesel
Post #994494 30th May 2023 1:38pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Any update?
Post #994926 3rd Jun 2023 12:23am
spudfan
Ireland
No, her mechanic has not taken it yet. I will update when I get any news. Thanks for asking. Thumbs Up 1982 88" 2.25 diesel
Post #994929 3rd Jun 2023 12:44am
spudfan
Ireland
Update. 90 is back on the road. It was the vacuum pump needed replacing. It was £85 for the parts (pump and gasket I presume) and £60 for the labour. 1982 88" 2.25 diesel
Post #995477 7th Jun 2023 6:53pm
