Home > Puma (Tdci) > Safari windows
Howard
Safari windows
I want to convert my 110 utility into a safari by fitting rear side windows. I notice some on the market are clear glass and some tinted. I can’t work out if my 2009 Puma is tinted or clear. Can I tell from the code in the existing glass?
Has any body else done the conversion, and which windows would you recommend, original LR of aftermarket?
Post #993693 22nd May 2023 8:25pm
spudfan
Ireland
My Puma 2.4 has a tint in the Alpine lights. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #994352 29th May 2023 12:40am
spudfan
Ireland
From the parts manual. There are two thickness alpine windows, 4mm and 5 mm. As far as I know the Puma is 4mm.
Post #994367 29th May 2023 11:19am
Linds Hanson
There is no such thing as a Safari unless you are looking at Citroen DS's? You will devalue a Utility by converting to Staition Wagon but if you really want to do it definatley only fit late spec new Genuine sliding windows. The sliding windows do start to rattle after a few years though.
Post #994422 29th May 2023 7:11pm
spudfan
Ireland
Seems I meesed up. I thought it was the Alpine lights, commonly called safari windows that you wanted! I read your post wrong. 1982 88" 2.25 diesel
Post #994426 29th May 2023 7:53pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Re: Safari windows
Can you see through it at 6ft away?
Here's mine. Front is "clear" which has a very light tint to it, rears are "tinted", both factory glass
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #994517 30th May 2023 5:05pm
