![]() | Home > Puma (Tdci) > Defender Fuel Rail Pressure Sensor 2.4 TDCI |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
Chaps
I've had a seemingly regular problem of my 2011 2.4TDCI Puma losing power and erratic stalling. Already replaced VCV, cleaned MAF and MAP, checked battery earthing, under drivers seat fuses/relays etc. New filters. No error codes on OBD reader... So I have decided to change the Fuel Rail Pressure Sensor This looks the right one (DENSO 55PP05-01): https://www.ebay.co.uk/itm/253437860242?ha...SwUOBdDiKI Before I order...could anyone confirm please? Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks for the info llessur
I have ordered the part, and also the thread sealant. I'm assuming I'll need to re- prime the fuel circuit and bleed all the air out after changing the fuel rail sensor. Fingers crossed. This has been going on a while now, and I'm really hoping to get my confidence back! It played-up in the M6 roadworks the other day, was terrifying surrounded by the lorries with nowhere to go (no hard shoulder). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Swim_Cap Member Since: 13 Oct 2019 Location: Cumbria Posts: 17 ![]() ![]() ![]() |
Hiya MartinK,
I know this an old post but did this solve your issue as I have the same symptoms and looking to replace the HPS - did you have to run any learn cycles with software or was it just plug and play? Thanks Matt |
Hi Matt.
No...in the end it was a succession of knackered VCV's... https://www.defender2.net/forum/topic85644.html?highlight=vcv Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thank you, how frustrating
