Home > Maintenance & Modifications > TERRAFIRMA RTC STEERING DAMPER TF835
defender.1986
Japan 2001 Defender 110 Td5 SW Java Black
My Defender has a MANTEC steering guard. Terrafirma Defender RTC Steering Damper.Can I install TF835? Has anyone installed it?
Post #993843 24th May 2023 10:58am
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
I fitted one but replaced it with a standard heavy duty one after a few years.
Worked at first but after muck gets into the collar that holds the spring it starts to move and is difficult to keep tight.
A bilstein one will be just as good.
Post #993956 25th May 2023 9:29am
defender.1986
defender.1986
Thank you for information. The TF835 has a thicker coil than the genuine one, so I'm worried about hitting the MANTEC steering guard.
Post #993972 25th May 2023 12:02pm
