![]() | Home > Technical > Red door light stays on sometimes. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
This has happened twice so far. I can't find anything in the manual to explain.
The red 'door open' light stays on after closing all the doors and starting the ignition. I first thought I'd left a door open or might have a faulty door switch. However, if I lock the doors using the keyfob, then open again, the light goes out as it should. No need to touch any of the doors, I just sit in the drivers seat. Is this a battery warning thing or an alarm warning? If not, what else could it be? |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369 ![]() ![]() ![]() |
What model truck do you have?
I think you're referring to the immobiliser/alarm light, I don't think there is a door open light on the dashboard TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
Regardless of model begin by taking a look at the door switches for corrosion.
If it was the door switch, why would locking, then unlocking make the light go out? I don't need to touch any of the doors!
It is the immobiliser/alarm light - it also comes on when doors are open. It's a 2015 110 XS SW. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6683 ![]() ![]() ![]() |
It'll be the battery in the fob!
A door switch fault would mean the interior lights don't behave. ![]() ![]() |
Thanks for that. Fortunately, I have the spare keys with me! It first showed when I was in the back of beyond on Hoy. No mobile signal and a long way down a barely used track.
