Home > Td5 > Electrical plug identification
mrodey
Sweden 2009 Defender 110 Puma 2.4 CSW Scotia Grey
I'm doing a full frame off resto on my 2002 Defender TD5 and I've come across 3 cables I need help identifying please. I've gone through the electrical manual and can't find a reference. Any help is much appreciated!!!
This one is on the main harness coming out on the left hand side of the shifter but I can't find anything it plugs into?
This one is on the offside attached to the engine block and I think it's an engine block heater since this defender has a cold weather package:
This last one come off the motor harness near the glowplugs and was wrapped in a plastic bag when I bought the car so not attached to anything.
Post #993187 18th May 2023 7:39pm
rallysteve
Third ones are for the EGR solenoids.
I dont recognise either of the other two as being original (at least on UK model). The round one looks very much like a block heater though.
Post #993189 18th May 2023 7:44pm
NickMc
Top one goes in the bracket bolted on top of transfer box and plugs into the fly loom for either diff lock of high low ratio switch
Think block heater 2nd
Last is for EGR on inner wing.
Post #993192 18th May 2023 7:55pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I' m also interested in the first one. Had found the same on 130 2006, and it is not hi/lo switch or difflock switch, both of these I have connected and working. I made a look through RAVE and found nothink. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #993199 18th May 2023 8:31pm
TexasRover
If you can identify the wire colours you can trace back original wiring at the following link:
https://www.lrworkshop.com/connectors/defender-2002my/colour
Post #993227 19th May 2023 5:32am
Martin
Site Admin
Wire colours are the best way to trace what wiring is, as connectors can be changed by previous owners due to damage etc.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #993235 19th May 2023 7:37am
MadTom
I went through schematics also with wire colours, but not find anythink. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #993350 20th May 2023 7:15am
mrodey
Same here... I could not find any matching references
Post #993421 20th May 2023 7:07pm
