Home > Td5 > 99 Defender 110 Rear door latch replacement
GI_Joe_Defender
Hello, i am new to defenders, and I have hit my first problem: my rear door won’t stay closed about 30% of the time. I was wondering if there is a recommended company to purchase the part through? Is Brit Part ok for latches? I have a 99 TD5 defender 110. Thanks!
Post #993001 17th May 2023 5:07pm
The Gribbin
United Kingdom 2001 Defender 90 Td5 HT Auto Caledonian Blue
Britpart have a mixed reputation... OEM would be my preference.
It might just need some adjustment/lubrication... I had a similar problem on my 110 in Zambia, but that was due to the dust... resorted to graphite dust - pencil lead to lubricate!!... any liquid, WD40 etc just gummed up with the dust.
A good mod, if you're changing locks is to upgrade all locks and ignition to a single key. Done this on my current 2001 90.
Post #993025 17th May 2023 6:59pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
As above, they don’t usually fail its does however fall out of adjustment. Post a picture of your door when latched. If its not flush its not properly adjusted. If you do need a new latch I suggest to you that Britpart is probably just fine. 🤷‍♂️
Good luck
https://www.lrworkshop.com/parts/FQJ500340 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #993164 18th May 2023 5:29pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
My experience with Defender locks is - remove, bath in brake cleaner and spray the cleaner through all holes with moving all parts. Than lube with some oil in spray ( oil not WD40), and than some grease spray. Nearly nor woking locks are now better than new. During last year I made it on three cars. Previous attemp to clean it without removing from car does not work. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #993201 18th May 2023 8:39pm
GI_Joe_Defender
Thanks all!
Post #993217 18th May 2023 10:21pm
