Home > Maintenance & Modifications > Rear door lock replacement
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
Hello fellow people,
So I bought a replacement rear lock as mine doesn't lock anymore. Have gone to fit it, but I'm encountering some issues...
1. I can't get the key barrel out of the old lock. No matter how much I wiggle a pokey thing in the hole it doesn't budge.
2. There isn't a hole in the same place on the new one. The part numbers appeared to be the same so not sure why the holes are in different places and if I swap the barrel, fear I'll never be able to get it back out... Or it won't stay in.
Has anyone come across the before?
New on the right, old on the left.
Post #992489 13th May 2023 5:31pm
TomB8
Quick bump to see if I am missing anything blindingly obvious before ordering a new spring to see if that fixes the old lock.
Post #992650 14th May 2023 11:01pm
Dinnu
You put the key in the barrel while pressing the thingy? Does the key rotate? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992654 15th May 2023 1:14am
TomB8
Key in, rotate until the hole in the barrel lines up with the hole in the case (?) press pointy thing in, pull on key. No joy. I pulled so hard the key starts to come out! No amount of wiggling or jiggling seems to help.
Even if I can get it out... How does it work in the new one that doesn't have a hole in the same place? The newer one does have a hole but it is inside the lock body, accessed through a slot that the old one doesn't have.
Post #992655 15th May 2023 2:07am
Dinnu
For your 2nd question, I wonder if you have the correct lock. The earlier locks (I think pre 2002) used smaller key, while after that they used the same key as the ignition.
The slot is for the central lock link. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992657 15th May 2023 4:42am
