Home > Puma (Tdci) > Broken Speedo Sensor, sheered bolt
Griffon
Hi,
A couple of days ago mid journey the speedo stopped working, and engine power reduced. Checking it out, the sensor was dangling from the wiring after the flange had broken. It's all corroded to hell and when I attempted to remove the mounting bolt from the transfer box it simply sheered off leaving around 1/4" sticking out.
Any suggestions as to how I could remove the remains of that bolt from such an inaccessible place?
Or any alternative ideas for fitting the replacement sensor and retaining it in some other way?
Thanks in advance.
Post #992580 14th May 2023 1:25pm
jst
Mine did this recently. Welded a nut on the stud and wound it our. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #992584 14th May 2023 2:11pm
Griffon
Thanks. How did you manage to access to weld? I wouldn't like to try with everything in place, did you remove the parking brake, or the whole transfer case?
Post #992587 14th May 2023 2:16pm
