Home > Puma (Tdci) > Sweak on engine
RobKeay
Sweak on engine
My 10my is suffering with a loud sweak that repeats four or five times. Doesnt matter if it's hot or cold it does it. The local dealer say egr cleaning but it's very loud any thoughts??
Post #98933 9th Nov 2011 2:54pm
dgardel
Italy
Re: Sweak on engine
gnek-gnek-gnek-gnek when you turn off the engine?
Yes is the self cleaning cycle of the EGR Valve Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #98940 9th Nov 2011 4:10pm
Lorryman100
It should sound almost like 5 x chukka chukkas. This is normal as the self clean cycle is working. If you do a search for the EGR, you will see that this has been covered in detail many times and will help you to decide whether or not yours is an issue or normal behaviour. Thumbs Up
Post #98942 9th Nov 2011 4:20pm
RobKeay
I've read some. But this also does it when you press the accelerator pedal! Also only started at about 30k! Don't know if that means anything!
Post #98973 9th Nov 2011 5:54pm
Lorryman100
It could be the EGR action is sooted up, and the squeak you are hearing when driving is the EGR valve responding to the inputs from the EMS under duress. Do you hear the chukkas when you shut down? If so, unplug the EGR valve electrical connection (you know it is closed) and go for a drive and see if the squeak still happens. You will get the MIL light and it may enter limp mode so just switch off and restart to clear it. If not then it would be a good bet the EGR is causing the noise. If it still sounds after the EGR is disconnected then it could be a number of things ranging from a loose accessory drive belt to a failing/dry bearing on the Air conditioning compressor, Vacuum pump, Coolant pump, Power steering pump, Alternator then there is the Crankshaft pulley and the Engine cooling fan pulley, and not forgetting the 3 deflection pulleys and the Automatic tensioner pulley. Shocked Also it could be the start of an air leak in the Intercooler/airbox hoses, or something has come loose or maybe you have a family of mice living in the engine compartment Whistle Confused
I'm afraid you will have to do a bit of fault finding to narrow down the source of the noise, but I would start with the EGR valve Thumbs Up
Brian.
Post #98998 9th Nov 2011 7:15pm
RobKeay
That sounds interesting I'll give that a go. I do always like to understand what the problem is without the work shop manager guessing. Think he had made his mind up before the landie arrived.
Post #99057 9th Nov 2011 11:32pm
RobKeay
Thanks lorry man really helpful. It's the EGR! Your detailed comment was great thanks alot!!
Post #99254 10th Nov 2011 10:29pm
ZeDefender
Re: Sweak on engine
Mine has 5 gneks...
p.s. sorry, stupid post but can't delete it for some reason Embarassed
Thumbs Up (hope that covers it) Tell someone you love them today because life is short.
Post #99257 10th Nov 2011 10:37pm
RobKeay
The local dealer has agreed to change it do all is good.
Post #99272 10th Nov 2011 11:14pm
