Home > Tdi > Defender TDI 200 oil housing filter block to gasket
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Dear all
I am going to change my engine oil soon, and I would like to change the oil housing filter block to gasket as well.
So do I need to apply the sealant on this gasket (as attached pic).
Thank you so much!
Post #992233 11th May 2023 4:14pm
geobloke
You need gasket ERR3607 https://www.lrworkshop.com/parts/ERR3607 - No/12
But if you have some gasket paper you can make one yourself.
Post #992237 11th May 2023 4:29pm
cykoh85
Re: Defender TDI 200 oil housing filter block to gasket
Ok, thank you.
But do I need to apply sealant on the gasket?
some leaks from that, hoping can solve the leaks issue after change it
Thanks Smile
Post #992323 12th May 2023 1:50am
geobloke
Officially... No... But... Some of these gaskets can be quite old stock so might be a little dryad hard. So yes a light smear of gasket sealer RTV is a good idea as it is unlikely you will want to remove the adapter ever again Thumbs Up
Post #992348 12th May 2023 10:16am
Dinnu
You do not need to for that application, but very small amount would not hurt. Do not put too much, as it will get into the oil passages, and could block somewhere later on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992369 12th May 2023 11:51am
cykoh85
alright, thank you so much Bow down Thumbs Up
Post #992674 15th May 2023 10:01am
cykoh85
Ok Sir, very clear now.
thank you Bow down Thumbs Up
Post #992675 15th May 2023 10:02am
