Home > Maintenance & Modifications > Another suspension thread - 110 DC (sorry)
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Hi,
I have been through pages of posts, and lost as to which way to turn.
I need new springs and shocks and it is clear everyone has their prefered setup/opinion.
I’m specifically interested in DC suspension that folk are using.
My rear springs I suspect are original at 160k, and presume they will be a heavy duty.
In terms of use I have occasional use for logs and stone, and will be overlanding later this year with roof rack and maybe a roof tent. Would like to improve comfort over what is a very crash/bang suspension currently.
One thought is alive, but currently considering more economical OEM springs and OME adventure shocks. No lift wanted.
Thanks for any thoughts.
Rob
Post #991478 4th May 2023 5:53pm
landy andy
Talk to Gwyn Lewis. He has sorted all my Defenders, including my 110 DC when I had it. It will be a slight 25mm raise but will do everything you want and more.
Post #991501 4th May 2023 6:51pm
DC101
Hi Landy Andy,
I’ve read a number of references to contact GL.Do you recall what springs you ran on your DC?
Thanks
Post #991513 4th May 2023 7:47pm
landy andy
No. Sorry. Each time i swap around I phone Gwyn he tells me what he recommends, tells me if not correct he will swap, but I’ve never had to.
Post #991528 4th May 2023 9:47pm
TexasRover
If not already present you should consider anti roll (anti sway) bars front and back. I recently fitted a set and the improvement is very noticeable making the car more car like with less steering required to cruise at speed. Also I found that as you take turns at slightly higher speeds you need to shift back less making for better progress all-around.
Post #991537 5th May 2023 6:31am
Assuming you have the original HD springs that provide the 1 tonne payload, you could do a lot worse than swapping them for progressive white/green/green station wagon springs. They transformed my USW that suffered the same problem. Darren
Post #991555 5th May 2023 9:16am
rustandoil
That's an interesting point about the station wagon springs, shame I've just had my original DC springs powder coated Rolling Eyes
Post #991560 5th May 2023 10:16am
rallysteve
I fitted a pair puma SW rear springs on my DC (progressive purple/brown stripe) years ago and it improved the ride a lot over the original springs. I always hated the nose down look it had, even with matching puma SW front springs though so swapped to a set of OME 2751HD fronts which levelled it out. There is a couple of threads on here which have one of my pictures showing the ride height difference at the front with the standard yellow/yellow springs and OME springs I used.
I ran a flatdog roofrack, heavy winch and winch bumper and a fairly large roof tent and found ride wise was fairly spot on, even with standard genuine shocks. ARBs are a must though unless you are doing serious offroad work as fitting those made the handling night and day.
Cheers,
Steve
[EDIT] Picture here:
 02' 110 TD5 Double Cab Rebuild Thread
Post #991568 5th May 2023 11:26am
Bundy
Another vote for Gwynn Lewis...
I got all my OME shocks and springs etc from him for my Puma DC and it now sits pretty level, maybe fractionally higher all round, but drives very nicely....even without a rear anti=roll bar.
I might put the roll bar back to see if it becomes a problem off road. On road it may lean a bit more but it's incredibly controllable and you can really hustle it if the need arises Cool
Post #991575 5th May 2023 12:36pm
DC101
Thanks for the replies.
Last weekend was 600kg of flags in the back and the rear end sat down significantly.
Should it do that? Or is it a sign of tired rear suspension? I’m probably looking for something that will do everything!
CSW springs sound interesting, but concerned for their rating - will check their rating weight wise.
Likewise will now look into an ARB. I seem to recall a demountable one for when things get rougher, but can’t remember who/where.
Many thanks All.
Post #991620 5th May 2023 10:10pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Agree, fitted to our 110 too and for the odd time you need to carry a heavy load why not fit the Airbag helper springs inside the green and whites.
Post #991633 6th May 2023 7:28am
DC101
I’ve not come across airbag helper springs before
Are they an easy fit - I’ll search the forum - and reliable and does it also mean I can safely shift the same payloads (on the rare monthly occasion?).
Thanks
Post #991984 9th May 2023 6:06pm
TexasRover
I think he might be thinking about the bags you place inside the springs and inflate. Pretty neat solution for occasional use.
https://www.devon4x4.com/air-suspension-aid-90-dis-rr.html
Post #991995 9th May 2023 8:05pm
