Home > Puma (Tdci) > Not starting
Page 2 of 2 <12
Vmax
Gibraltar 2008 Defender 110 Puma 2.4 SW Baltic Blue
Excellent thank you very much for your help.
Post #991037 1st May 2023 6:12pm
Ianh
Have you any other cables attached to either of the bolts that clamps the main cables to the battery, in particular the earth cable clamp to the battery ? I ask as that stops the clamp gripping the terminal and can cause an intermittent fault in starting and when engine is running. If not loosen battery clamps, tap down but not too hard, then re tighten battery cable clamps.
Post #991040 1st May 2023 6:27pm
Vmax
All standard fettings.
Will do cheese.
Post #991062 1st May 2023 8:19pm
Ianh
I always find its best to use standard fettings when I do cheese as well Rolling with laughter
Post #991069 1st May 2023 9:08pm
Vmax
There are putting a complete LOF clutch at the moment.
Post #991073 1st May 2023 9:18pm
hornet
If they do that, now would be the best opportunity ever to perform these test to be able to work on the starter....
Post #991138 2nd May 2023 10:50am
Vmax
On the process thank you
Post #991151 2nd May 2023 12:28pm
Page 2 of 2 <12
