Home > Maintenance & Modifications > Finally got around to connecting my roof lights
Kez
Isle Of Man
Quite effective don't you think Whistle
Post #98968 9th Nov 2011 5:48pm
DAZ110
The Aliens have landed! Shocked
Post #98971 9th Nov 2011 5:49pm
pom
sure make chasing down those sheep at night easier Thumbs Up
Pom
Post #98985 9th Nov 2011 6:39pm
Kez
Isle Of Man
Pom
It was just the once and the sheep was over 18 ok!
Post #98988 9th Nov 2011 6:45pm
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
What lights? thinking of sorting mine in the next few days before the next trip up the A9!!
Post #99004 9th Nov 2011 7:54pm
110SEB
Kez, what did you use - a LR loom or are you an expert sparky yourself?
Post #99015 9th Nov 2011 8:29pm
Kez
Isle Of Man
The dash switch and wires were already there just terminated behind dash near door, so was relatively simply to extend them onto lights on roof. Not being an expert by any standard I held my breath when i turned them on, half expecting loom to melt!
Post #99039 9th Nov 2011 10:09pm
K9F
What route did you take to get the cables into the cab and how many cables did you run? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99059 10th Nov 2011 12:15am
Kez
Isle Of Man
Four lights in total wired in pairs to one four core cable, that then runs behind roof bar, down support leg on drivers side then in behind door seal until level with dash just above door stay. Very simple to do (had to be or I would never have done it).
Can take a photo if you want but as most of its hidden not sure it would be much help
Kez
Post #99069 10th Nov 2011 8:00am
110SEB
Have you cut the door seal Kez, or does the cable squeeze in behind? Any problems with the door sealing now?
Post #99076 10th Nov 2011 9:20am
JWL
If his panel fit is anything like my TD5 then it would just slide through with no cutting Laughing I have 2 roof rack spots with twin cables to both, flashing led's and an external temp sensor all entering through the top corner and all pass underneath the door seal. They don't cause any draughts or water getting in(there's plenty of other places for that Razz )
Post #99077 10th Nov 2011 9:34am
Kez
Isle Of Man
As JWL says, plenty of room to simply fit behind seal, absolutely no problems with wind noise or water ingress as a result, think you could easily run a TV coax behind if you wanted Shocked
Post #99078 10th Nov 2011 9:48am
Kez wrote:
absolutely no problems with wind noise or water ingress as a result, :
So by doing this we fix Water ingress issues Rolling with laughter Wink Thumbs Up
Post #99097 10th Nov 2011 10:44am
Kez
Isle Of Man
Strangely enough apart from the sunroof (now fixed) mines as dry as a witches tit, no leaks anywhere. Having said that and to put this into context, this is the 4th Defender and 6th land Rover I have owned, they all leaked like sieves Rolling with laughter
Post #99105 10th Nov 2011 11:04am
