![]() | Home > General & Technical (L663) > Grille in hard top bulkhead |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
The whole bulkhead is. Not sure about just the grille.
| ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777
The grill is a separate piece to main bulkhead
| GeeWhizRS Member Since: 01 Apr 2023 Location: Preston Posts: 6
Is the bezel just a press fit?
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3529
No it's bolted on, but you can remove it.
It doesn't make much difference to the view in the rear view mirror, which is mostly of the spare wheel. But you can see enough to make it worthwhile. |
Thanks for that. There was nothing ont’internet I could find about it. 👍
| BolloB Member Since: 30 Apr 2023 Location: Scotland Posts: 3
Hi, did you manage to remove the grill? My one arrived and I’d like to retain the bulkhead but remove the grill. I was thinking if I could remove the grill bezel, remove the actual grill then replace the bezel then that would be the neatest solution. Any advice on how to remove the bezel without breaking it apart? Cheers
Mine hasn’t arrived yet. If there are no obvious fixings visible then assuming it’s not all moulded as one part I could image it being a push fit from both sides. Are there no fixings visible?
There isn’t anything obvious. I’ll take some pictures and will share tomorrow
If there is a visible gap between the grille surround and the main bulkhead then it probably clips together in two pieces. Probably very easy to
Okay I’ve finally had a go at removing the bezel around the grill. It was surprisingly easy and nothing ended up being broken. The bezel is attached to the grill via metal clips that pop out easily with a trim tool. The grill can then be removed. Note that the bezel clips into the grill meaning when you remove the grill the bezel has nothing to clip back into. I captured some pictures. Hopefully you can see them in the gallery
Nice one mate. Thanks for taking the time to post. 👌
| Davedig Member Since: 18 Feb 2024 Location: England Posts: 36
I don’t suppose anyone has a spare grille knocking around they don’t want?
