Home > Faults & Fixes (L663) > Defender Center Channel speaker
Defhead
United States
My Defender have the 400W 11 speakers package. I noticed the other day that on the dashboard there is this square shaped thing which had speaker under it. I found that its called center channel speaker or tweeter speaker. I removed the plastic cover and noticed that the speaker doesn’t work on my carplay and radio. Does anyone have an idea if this was a fault or Land rover just had these speaker on all models and work only if you have the 700W package. Please help me out
Post #990854 30th Apr 2023 9:05am
whiterdesign
The 11 speaker system does not have a centre speaker, so it’s odd that there is one fitted, but as you say it doesn’t work. See info below
https://www.lrdefender.org/speakers-818.html 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #990918 30th Apr 2023 8:50pm
Defhead
United States
Thanks whiterdesign for your reply and the link is so helpful
You can see the image that there is a speaker and i also opened the trim and found it already wired.
By any chance can i get it to work or should contact the dealership about?
Post #990951 1st May 2023 6:06am
mf7480
What engine do you have? Is it a speaker for false engine noise?
Post #990953 1st May 2023 6:30am
Defhead
United States
Hi mf7480
i have the 110 HSE P400 I6
Post #990985 1st May 2023 11:10am
lightning
Well, that another feature l don't have to worry about on my base spec Commercial
All l have under that cover is a hole.
TBH l am surprised the audio system sounds so good with only two door speakers and two tweeters. When you are moaning about your "lousy" ten or thirteen speaker/sub setup, think of me with four speakers and no sub.
Post #991487 4th May 2023 6:30pm
Defhead
United States
Drink some tea it might help
Post #991572 5th May 2023 11:57am
