Home > In Car Electronics > What and why..??
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
What and why..??
Hello,
I'm getting so fed up with this Censored vehicle....
I thought I'd start the weekend off nice and easy by replacing the dash speakers.
Passenger side was straightforward but when I removed the drivers side speaker something that looks like a cross between a block connector and a relay fell out along with a bridging wire...
Any ideas what this is and which terminals the frig wire should be in..??
I'll need to make a new wire as the existing terminals are far too small.
There is also a spare, bare wire hanging down. Again, any ideas gratefully received.... 😊
Cheers all 2002 Land Rover 110 Td5 Utility
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #989855 21st Apr 2023 9:31pm
Oldowner
Block connector is the base for the dim dip relay which has been bridged out. If you search for dim dip relay bridged out you will find which way it should be bridged out - it is a very common mod to remove a useless function that often goes wrong and is no longer required. The base should clip to the bulkhead on a relay clip just above the dash speaker
Bare wire is the aerial for the 10AS alarm / central locking from memory, and is just left as is.
Post #989859 21st Apr 2023 10:04pm
Evil Elsie
Thank you very much Oldowner - very much appreciated... 👍👍 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #989905 22nd Apr 2023 10:35am
Evil Elsie
There is quite a bit about the 'dim-dip' isn't there..?? 😁
One last question - would my Utility have an alarm..?? It doesn't have central locking or any other niceties - it lives up to its name.. 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #989928 22nd Apr 2023 1:12pm
Evil Elsie
It's ok - found the info...
All Td5 Defenders have a 10AS alarm module of either a basic 270 or a more advanced 280 model.
270 - which I must have won't control Central Locking and is 'disabled' in the case of mine.
That's what I've read anyway.... 👍👍👍 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #989952 22nd Apr 2023 3:51pm
