Home > Technical > Coolant issues
Inguz
Coolant issues
Hi all, I’m having a strange problem which is driving me nuts.
I fitted a new AMC head on my TD5. While doing it I put in a new water pump. Car starts and drives fine but the temp gauge is fluctuating.
It usually sits on the higher side. The strangest thing is it goes higher when I turn on the heater. The radiator stays cold along with the bottom pipe while the top gets hot but has no pressure.
I’ve tried bleeding it a couple of times with no success. I’ve taken out the thermostat and it works fine.
I’m a bit lost here now. Would love to hear if anyone has any ideas.
Post #989948 22nd Apr 2023 3:38pm
TexasRover
Use a infrared temp meter to check the block temp after some driving. With what you describe sound more like an electrical, most likely earthing issue.
Post #989954 22nd Apr 2023 4:03pm
Inguz
I was thinking (hoping) it’s an electrical issue. I don’t want to pull the head again. Thanks for the idea, I’ll get on it.
Post #989965 22nd Apr 2023 5:13pm
geobloke
Does the temp gauge always rise when you turn the heater on?
Post #989973 22nd Apr 2023 5:53pm
Inguz
Yes every time. Some times it rises then drops a little but it’s always higher than when the heater is off
Post #989974 22nd Apr 2023 6:08pm
barbel jim
Could well be an earth issue. Mine was related to the earth post, in the seat box y the drivers seat .I ran a new cable from said earth post to chassis, cured my dancing temperature. Just use a jump lead to a good earth point, and check the earths. It’s pretty quick and simple.
Post #989976 22nd Apr 2023 6:20pm
