![]() | Home > Wheels & Tyres > Spare wheel carrier - again ! |
I beg to differ Brendan - on any Hi-Cap you are correct but a 'standard' 130 should be ok. This is a photo of a mate's old 130 with a wheel carrier fitted to the rear cross-member. ![]() Click image to enlarge Edited to add; If the original question was for a 130 HC then my answer was indeed, a load of cobblers ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
That must be home built ? all 130`s have the hicap back don`t they.
Hi Blackwolf
I have one left right now from this batch but i will be getting some more made up in the next couple of months ![]() |
Not sure, I know a lot are HC - perhaps they were a SV build then? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
That is one of the 'interesting' things about Land Rovers. The number of variations that are around.
Hence why I say ensure that any piece of aftermarket kit will fit your particular Land Rover and is compatible with anything else you are likely to buy! Sonic, I have no idea where they got the idea of high/low mount position from. Safari do a wheel carrier for pick ups but not single pivot ones ![]() Click image to enlarge Kaymar do a single pivot one (IIRC) for pickups. However the price is eyewatering! Brendan |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Brendan does the safari equip single pivot swing out with the door or is it a two stage operation to open the rear door?
Kmac it is a single operation for single pivot rear door.
For the Kaymar single pivot and most of the other swingaway wheel carriers on a drop down tailgate it is a two operation opening. HTH Brendan |
Are these still available and if so how much do they cost? |
Contact Andy at Allisport as they are now sold through them
