Home > Td5 > Replacing sliding side windows
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Morning all!
I've purchased some replacement sliding side windows for my 90, before I go about swapping them over can someone tell me if you need to Rivet and bond them in or is it rivets and single sided seal only (MUC1008?)
It's a 2003 if that makes any difference
Post #989582 20th Apr 2023 7:07am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
I riveted it in, used the gasket you referenced and put some sealant on it too
Shane
Post #989595 20th Apr 2023 9:02am
2hel
Ah ok brilliant, ill order the gasket anyway then! Thumbs Up
Post #989613 20th Apr 2023 10:35am
shanecl
be careful when riveting in, you will need someone the opposite side pushing the panel back against you as I was doing it on my own and luckily seen the panel was also moving leaving a gap
Post #989621 20th Apr 2023 11:33am
