![]() | Home > Maintenance & Modifications > Alive Shocks for DC. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
sorry double post
I run Koni on my 110DC seem to be OK for me, but the rears rotted away before any problems with leaking or loss of function
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
I’m sure many will disagree, but for me Alive suspension is for fast road driving (I don’t really understand fast road and Defender. But that’s me). OME is for Overlanding, off roading, and loading up.
OME on my 3 Defenders as I use them for what they were designed. |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 269 ![]() ![]() ![]() |
Thanks for replies.
I’ll check out the specs for OME for my DC. I spoke to Alive, and think I am correct in saying that their shocks sit between fox’s and B6’s. Still a lot of money, though |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 413 ![]() ![]() ![]() |
I think the term it used to describe the drive you get from the suspension setup. If you are using mostly on the road then the Alive setup is superb. However if you drive for a large part off road then the Alive setup which is mostly about going round corners and comfort would not be for you. For me the road setup has transformed the 90 having done the 2” lift stuff for Morocco. I now mainly am on the road and appreciate the nicer ride and handling the setup gives. Not to say that it has really impacted what I do on our farm either. For towing (on road) though I find the road setup is brilliant. |
