![]() | Home > For Sale & Wanted > [For Sale] More garage tidying out tat... |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 821 ![]() ![]() |
I am interested in the ECU if it will work on 2002 td5, will it need coding to the Defender?
Many thanks. BORG - Bucks & Oxon 4x4 Response Group ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
I just paired it with the 10AS on the 90 I had. Was a 15P if I remember right
whitepeakwolf Member Since: 03 Feb 2021 Location: Peak District Posts: 36 ![]() ![]() |
Wiper wheel box please, if you could post ?
Cheers ![]() ![]() |
^^^ no problem. PM me your details
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1890 ![]() ![]() |
Hi Jim,
I’d take the Tdi tensioner off your hands, thanks. I’ll send a PM. Cheers Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 297 ![]() ![]() |
I’ll take the two rear brake disc guards if they are still available and you are able to post .
Cheers Leigh 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
^^^ Yes & yes
![]() so disc guards, Timing idler, wiper box and ECU have now gone. |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 435 ![]() ![]() ![]() |
is the td5 turbo heat shield still avaliable, if so would you post in the £30?
I'll check how much postage comes to and let you know
Can do it for £32 posted |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Could I have the gearbox thermostat bypass/sensor please?
Let me know how much incl. postage ![]() Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
No problem
Hi buddy, perfect, if you can DM me you details, happy to get that sorted and transferred asap . |
oil temp switch
ECU disc guards heat shield wiper gearbox Tdi idler These items have now gone. Thanks ![]() |
