Home > For Sale & Wanted > [For Sale] 1985 90 Heavy Duty Off Roader (early 'pre' defend |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
For sale - with a heavy heart / My Land Rover 90 1985 (Ashcroft locker/lsd Diffs, shafts, 24v 8274 winch front, goodwinch rear, +4 suspension with proper arms, triple battery setup, 200tdi 2500 engine top mount turbo, 35” beadlock wheels)
As you can see and tell this is a serious bit of kit and a bit different to some of the very sleek all usage vehicles on d2! Its in Camberley Surrey UK. Full video walk arounds: https://youtu.be/kkqRQTdO8B0 https://youtu.be/u6IfvJN4sns This has been a huge project for me over the last 6-7 years and started relatively standard. It has sat around barely used for the last year. Was mostly rebuilt during covid and then marshalled the 2021 ultra4 series in the UK. Needs MOT - which I am working on getting sorted shortly. It will go through fine and will be done shortly time allowing! Open to offers based on this. Its an honest and genuine vehicle, please watch the videos. Life has moved on and so must this fun and solid vehicle OPEN TO OFFERS - Its up for £12000 which is easily worth it for the base vehicle, the diffs, winches and all the bits! The lengthy full spec (just ask if you think I've missed something) Chassis + Engine 200tdi Defender engine (proper defender one not a disco lump). Çambelt change a couple of months ago. Oil change recent. Recent rocker gasket and tappet setup. Larger intercooler and thicker core radiator about a year old. Ford transit electric fan that quickly releases using wing nuts for easy rad washing and service Recent water pump and PAS pump. New alternator a month or so ago. Has a Gwyn Lewis 200tdi second alt mount (rare and expensive) running a large 24v truck alternator. Wiring on 50mmSQ cabling send and return to a pair of Northstar AGM24 batteries wired in series with an Alrbright contactor controlled from dash, to provide power to winch electrics. Decent 12v battery and standard 12v system for ignition etc Land Rover Series doors with removable door tops and sliding windows Modified dashboard with various switches for air lockers, compressor, lights etc Snorkel that mounts onto cage Aftermarket carbon airbox and oversized pipework Recent starter motor works well Side exit custom exhaust Steering guard bar Chequer plate on bonnet wings and rear panels Recent fuel tank last year Series headlight surrounds Tomcat wheel arches All bushes are Superpro (the best and far better than Polybush) Steering Original narrow bush variant NA/200tdi early front axle casing with WIldbear cranked radius arms. Ashcroft LSD differential built by Nigel Xcess4x4, pegged diff casing Front Ashcroft 300m half shafts New CVs with around 2000 miles on them tops. Terrafirma HD steering arms with recent ball joints. Terrafirma HD pan hard rod. Rear Terrafirma Johnny Jointed trailing arms with new axle ball joints (2 months ago) and fully grazeable) 300tdi Disc rear axle from 98 Discovery Rear Ashcroft Air Locker with pegged casing Ultrabuild by Nigel Xcess4x4 Rear Ashcroft 300m half shafts and HD flanges Electrics Keith Gott LED spots and floods all around the vehicle Wipac LED conversion indicators, repeaters and tail lights etc Halo ring LED headlights ARB Air compressor with large air tank for tyre inflation and air locker etc Air train horn on dash switch Hazard strobe lights front and rear with internal flash controller PUMA heated seats Winches Warn 8274 front with 12v Red winch OX motor running overvolted 24v, all recently serviced and pulls well, 2 wireless remotes on Devon 4x4 bumper (v expensive bumper) which is mounted to shortened chassis rails with extra mount points on front X member Rear winch Goodwinch 9.5c on Dixon Fab winch tray running 12vmotor overvolted with wired remote in cab Wheels 5 x Beadlocked 15 x 10j wheels with 5 x Creepy Crawler 35” x 12.5 with loads of tread Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Insta: @thebenjordan4x4 |
13th Apr 2023 7:52pm |
No interest?
Where do you guys think I should be at with price? Insta: @thebenjordan4x4 |
23rd Apr 2023 5:48pm |
