Home > Puma (Tdci) > Seat belt fixing bolts - puma dc 2013
edward
Hi all. I’m replacing my seatbelts and I can’t work out the size of the 3 bolts that hold the front belt bracket (the triangle one) because the current ones are seized on.
Does anyone know what they are?
Also the bolt that goes horizontally towards the rear seems stuck in - should it just screw out? I can only get it so far before it just spins….
Cheers Ed.
Post #988745 12th Apr 2023 3:41pm
Dinnu
On a 90, they are M6. Also on a 90, the horizontal bolt goes into a square nut held captive by a flimsy steel bracket. That nut usually starts spinning with no effort at all.
Edit: I just realized that it is a DC in the subject. I do not know how the horizontal bolt fits in the B pillar of a DC. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #988747 12th Apr 2023 3:53pm
edward
Thanks anyway. I think you’re right they are m6 -
and the horizontal nut sounds as you suggest, it’s just odd I can’t unscrew it fully - or pull it out with nippers, I get it some way out and then it just spins…it does feel like it’s still held in, but by what I can’t work out. Ed.
Post #988809 13th Apr 2023 7:57am
Dinnu
LRWorkshop diagram. See position 12 for the captive nut. But again, no idea if it applies for a DC. But does not mention anything specific as being for a 90.
https://www.lrworkshop.com/diagrams/land-r...mbly_44885 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #988811 13th Apr 2023 8:13am
edward
Yes. Looks the same. Ok just done more jiggling / brute force I think. Cheers!
Post #988813 13th Apr 2023 8:17am
