Home > Puma (Tdci) > New or refurb
Ad-doublecab
United Kingdom 1995 Defender 110 300 Tdi DCPU Loire Blue
New or refurb
Hi all,
Looking to replace the turbo and injectors on a 2.4 tdci (97k) what’s everyone’s thought on refurbished turbos and injectors or would I be better off going new?
Post #988683 11th Apr 2023 9:34pm
BrickBox
Go new. It’s a fit and forget job for the next 100k then, roughly. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #988685 11th Apr 2023 9:47pm
Ad-doublecab
Thanks brickbox was hoping to save a few quid but I guess it makes more sense to go new!
Post #988686 11th Apr 2023 9:55pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Are you changing due problems or as a precaution due to mileage?
I ask as mine is on similar mileage approaching 100k.
Post #988689 11th Apr 2023 10:43pm
Why do you think that they need replacing? They should last much longer than that.
Post #988690 12th Apr 2023 2:19am
Ad-doublecab
Reason I was thinking of replacing the turbo is i had the top intercooler hose off with engine running and it’s spitting out a fair amount of oil?
Also in low revs it doesn’t feel a smooth delivery of power it’s hard to explain but it’s also most slightly hesitant then smooths out the fast you go
I’ve cleaned the maf and the map sensor, map sensor was covered it soot
I’ve replaced the scv new fuel filter and oil air filter.
Post #988698 12th Apr 2023 8:38am
hornet
I recommend checking the crankcase ventilation also....
Your description makes me think of another leakage.
Post #988702 12th Apr 2023 9:15am
Ad-doublecab
Thanks hornet, what other leakage??
Post #988703 12th Apr 2023 9:19am
hornet
Your description of "hesitation" makes me think that. Do you hear a turbo-whistle as well? Maybe it is not only one problem. A smoke test to check for leaks (intercooler, piping etc.) would be very helpful.
Edit: delete EGR if possible
Post #988732 12th Apr 2023 2:19pm
Ad-doublecab
Maybe hesitant wasn’t the right word it just doesn’t feel right, I’ve fitted a new allisport intercooler with new hoses.
So I’ve just used forscan and tested the injectors
Cylinder 1 -0.383mg
Cylinder 2 -1.492mg
Cylinder 3 -1.89mg
Cylinder 4 3.79mg
Looks like one injectors faulty on cylinder 1?
Another thing that didn’t look right was the air in take temps
IAT 87c
IAT2 16c
Cylinder head temp 53c
What sensor takes the the first IAT?
Thanks again
Post #988736 12th Apr 2023 2:31pm
Ad-doublecab
Update new injector seals and maf have fixed the issues!
Post #988864 13th Apr 2023 6:34pm
