![]() | Home > Maintenance & Modifications > Manual window questions |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 234 ![]() ![]() ![]() |
Done a few times on mine in various positions of window stuckness if you know what I mean.
Best way is take door panel off and see what the problem is. You can still operate the window by putting the winder back on. Usual problems are bent teeth on the winder or something jamming the runner. Have a good look and lubricate everything and manually move the window. Be careful not to damage the door lock mechanism and take a photo of the position of the plastic bits that hold the it all together. Easy to knock off and forget how they go back. |
TomB8 Member Since: 17 Nov 2022 Location: West Sussex Posts: 117 ![]() ![]() ![]() |
I've had the door panel off and there is no movement at all in the regulator, it seems to be stuck fast. I did start to take the piece of metal that the regulator is attached to out and the whole thing (window and all) started to drop out. Unfortunately, at that time the car was parked too close to a hedge so I couldn't open the door enough to drop the assembly out.
Maybe I'll get a second pair of hands and try again. |
Sounds like the spring it the actuator has snapped
Like you say best to dismantle the whole thing and rebuild Gives you a chance to rust proof the door frame. Good luck |
Cps16 Member Since: 13 Aug 2025 Location: York Posts: 2 ![]() ![]() ![]() |
I’m having issues with both rear windows. I can roll them down about six inches but after that the plastic tray on the regulator holding the glass pane pulls away. Is it a case of the window getting stuck?
