Home > For Sale & Wanted > [For Sale] One ton ‘204 rims
gcc130
I have a set of five 569204 forward control/one ton rims I don’t think I’m going to use.
I was going to get these blasted and primed but they are in good condition and don’t justify blasting.
Three are bronze green, one limestone and one in primer that doesn’t look like it’s ever had a tyre fitted.
Looking for £875 collected from Wiltshire, I will pack on a pallet for your courier if required.
Post #988191 7th Apr 2023 8:59am
Nice. Super cool these are. Cool
Post #988226 7th Apr 2023 7:46pm
gcc130
Thanks, I run them on my series one, they fill the arches nicely and the offset improves the turning circle.
Post #988248 8th Apr 2023 9:35am
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Not sure that will help?
If the wheels are 1” wider and the centre of the wheel is 1/2 inch further outboard, then the inner edge of the wheel rim will be in the same place.
If you are comparing the same size tyres on both 5.5” and 6.5” rims, then the tyre will be a bit more stretched I suppose, but not by much.
That’s why they changed the offset for the wider rim!
Post #988299 8th Apr 2023 8:23pm
camelman
204s have a deeper offset than standard rims so end up with a wider track, not a narrower or equivalent track. The super rare 203s are half an inch deeper again but sell for around £400 a corner.
Good article here https://www.onetonlandrovers.co.uk/index.php/wheels-and-tyres/
Post #988337 9th Apr 2023 10:35am
v8bob
Yes wheel track, which is measured at the centre of the wheel, is wider,
But inside edge of rim remains the same (within a mm anyway) due to the reduced offset.
Outside edge of the rim is an inch further out each side.
This is comparing 5.5x16 33 offset to 6.5x16 20.6 offset.
Post #988341 9th Apr 2023 11:08am
camelman
The various styles of 6.5 inch 'deepdish' wheel don't all have a +20.6 offset though
The 569203s are closer to zero, I recently sold my last one so can't measure it exactly...
Post #988344 9th Apr 2023 11:53am
v8bob
Lots of free bumps to sell the wheels….
I suspect the 569203 was 3/4” less offset.
So in old (proper) measurements,
1-5/16 has 33mm stamped on them. I think I did see some stamped 33.3mm
13/16 has 20.6mm stamped on them
And I guess the 1/16 is what the 203s are but don’t appear to have an offset stamped on them.
I have also heard there are some 203s that are pushed out further. Probably by an extra 1/4”
The 569204 is quoted as being superseded by anr1534.
My 3 sets of 6.5” steels all have the 20.6 offset stamped on them.
Post #988354 9th Apr 2023 2:29pm
22900013A
FWIW none of my 204 or 203 rims have any measurement stampings on them, I always assumed that to be a later (1980s?) feature. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #988358 9th Apr 2023 3:13pm
