Home > Puma (Tdci) > ABS activating
Grizwold
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
ABS activating
I'm regularly getting the abs/tc kicking in, mostly when turning and pulling away in first but also in 2nd and occasionally in 3rd. Sometimes the TC light comes on but not always. It seems to occur as the clutch engages gear and more so if I release the clutch quickly.
I touched on this in a previous thread and was advised to tap the abs sensors home, which I did and they visibly moved about 1mm or so, but the problem is still there, any clues?
Thanks in advance
Post #987658 2nd Apr 2023 6:52pm
Bluest
What model Def is it? I recall that on 2.2 Pumas the steering angle sensor can cause ABS/TC weirdness if it out of alignment. 2007 110 TDCi Station Wagon XS
Post #987663 2nd Apr 2023 7:00pm
Grizwold
Sorry - its a 2.4 Puma and apparently it doesnt have a steering sensor.
Post #987664 2nd Apr 2023 7:05pm
Bluest
Ok so have you checked for any play in wheel bearings? Other things.... Any damaged wiring to the the sensors? Tyre pressures all good? Have you a diagnostic tool that can read the ABS for trouble codes? 2007 110 TDCi Station Wagon XS
Post #987668 2nd Apr 2023 7:38pm
Grizwold
Thanks, wheel bearing play maybe worth checking. I have a gap IID tool and there are no fault codes and all wheel sensors are reporting back at slow speeds, bur haven't really checked each one individually yet.
Post #987669 2nd Apr 2023 7:44pm
Grizwold
Tyre pressures are good and wheel sizes all original. If its relevant it seems to happen more when turning right.
Post #987671 2nd Apr 2023 7:45pm
hornet
Re: ABS activating
Thanks in advance
I have exactly the same thing for 15 years now, from the first day I owned him. It doesn't get worse, but it's never gone away. A lot has been done to the axles in the meantime, but the issue remains. It will not help you but it calms perhaps Wink
Post #987702 3rd Apr 2023 6:15am
Grizwold
Thanks Hornet, I am driving with it, but the more I look into it the more it's driving me mad! I think after 15 years I would be a gibbering wreck, then again I probably will be anyway.
I can drive super gently slipping the clutch really carefully and it doesn't happen but that's really not the answer.
Cheers anyway. 👍
Post #987708 3rd Apr 2023 8:40am
Grizwold
I was hoping to use the GAP IID tool to watch the sensors when it happens but it appears you can only watch the sensors at super slow speeds and all I can really tell is that they're all reading something. Unless anybody can advise otherwise...
Post #987709 3rd Apr 2023 8:43am
Bluest
Could you try systematically moving the sensors around see if you can isolate the problem? I.e. the issue moves from turning right to turning left when you swap the front sensors, you have a culrpit. Or get hold of a single replacement sensor and swap them out one at a time? (Assuming all 4 are the same). Of course it may not be a sensor issue. The system is fundamentally quite simple on the mechanical side so it shouldn't be too hard with a bit of time to satisfy yourself that everything physical is on order. 2007 110 TDCi Station Wagon XS
Post #987729 3rd Apr 2023 10:40am
It's highly likely that the system is working perfectly (hence no fault codes) and that the actual fault lies with the wheel bearings. Darren
Post #987733 3rd Apr 2023 10:48am
Grizwold
There may be a theme developing here.
I'll jack it up later and check wheel bearing play etc.
Thanks again, I'll keep you posted
Post #987750 3rd Apr 2023 12:58pm
Grizwold
Will I be able to feel any play in the wheel bearings by hand? And if so is it new bearings or can I repack and tighten, assuming they feel ok.
Post #987778 3rd Apr 2023 4:01pm
Grizwold
Ok - quick update I've jacked up and checked both front wheels and the wheel bearings appear to be fine.
I also viewed the live data on the GAP IID tool and both wheels are showing the same values (although I'm not sure why they both sit at 1.1mph until you rotate the wheel.)
I've only jacked and checked the fronts as I'm assuming its more likely there as it seems to do it more when turning. Although all wheels show similar figures on the GAP tool.
Not sure where to go from here, I have had a quick check on the abs module for loose connections as it seems to do it more if you let the clutch snatch a little rather than a smooth release.
Rolling Eyes
Post #987801 3rd Apr 2023 6:02pm
Grizwold
Another update, in case anybody's interested.
I've replaced both front abs sensors.
I've replaced rear offside wheel bearings and seals (as there was a small leak) inspected and checked abs sensor but haven't got round to changing the rears as yet - but its on the list.
Still have the same issue every time the car hits a bump in the road or a bit quick on the clutch the abs/tc kicks in for about 2 seconds. Its almost always when turning right and almost never when turning left or straight ahead.
Its doing my head in, but I'll keep you informed. Rolling Eyes
Post #1000760 18th Jul 2023 7:12pm
