Home > Puma (Tdci) > My 2.4 is only starting intermittently
Greg H
United Kingdom 2014 Defender 90 Puma 2.4 HT Aintree Green
Struggled to start this morning
Turning over fine fired then stopped every time eventually it started so I let it warm up for half an hour to recharge the battery drove it to the fuel station filled up then wouldn’t start again
Called for a toe h plugged it in. No fault codes. Then it started got it home now it won’t start again
Same as before. Fires once then stop’s
Any idea please
Greg
Post #987643 2nd Apr 2023 4:29pm
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Maybe the immobiliser?
I believe a flat battery in the remote (or it not there at all) will allow the engine to turn, catch and the give up. I have a feeling that the remote needs to be very close to the front .
Also, I bout one of those all in one key/fob. I have to wait around 10 seconds before cranking otherwise the same happens.
Good luck
Post #987644 2nd Apr 2023 4:53pm
Greg H
The man from the AA suspended the immobiliser bu couldn’t see it with his reader
However the same has happened with my spare key’s
Post #987645 2nd Apr 2023 4:57pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Have you got both keys in the cab at the same time? if so then this will block the vehicle starting - this happend when I went to sell my previous 110 - put both sets of keys on the same key ring and it confused the immobiliser ..
just a thought ... Whistle Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #987649 2nd Apr 2023 5:48pm
Greg H
No just tried my spare keys and left the other in the house
Post #987650 2nd Apr 2023 5:59pm
Ianh
Has the red alarm light been illuminated when the engine is running ? that’s a sure sign the fob battery is low.
First thing to do is change the fob battery, it’s easy to do, then resync the fob by pressing lock four times with the door closed, then unlock once.
Then try the key with the fob attached to the key ring the key is attached to.
If that does not solve the issue it could be the ignition switch, lots of topics on here re that failing and how to replace the switch element. I.e https://www.defender2.net/forum/topic56773.html
Post #987656 2nd Apr 2023 6:33pm
Greg H
I’ll try that
Thanks
Post #987659 2nd Apr 2023 6:55pm
Greg H
Tried new battery in the key
And fully changed car battery
Still the same
Any idea how to check the immobiliser 🙏
Post #987672 2nd Apr 2023 7:49pm
Ianh
I don’t think it’s the 10AS alarm unit. It could be the instrument cluster (IPAC) , you can try the instrument cluster shunt, you remove the IPAC, remove the wiring connector to it, leave it unconnected and bridge pins 3 and 4 with a paper clip or equivalent size solid wire, and with the IPAC still disconnected and connector pins 3 and 4 bridged with a wire try and start the engine as normal.
See page 7 of this topic near bottom, post from Martin. https://www.defender2.net/forum/topic47486...p;start=90
This is the connector on the IPAC
To release it Push down on tab (green arrow). This releases the latch which you swing across (orange arrow).
I obtained these pics from posts by Martin (site admin and owner) and Redline ( member) , thanks to them for posting
Post #987674 2nd Apr 2023 8:05pm
Greg H
Thank you so much for the information
I’ve read through the posts and it seems to make sense
I also managed to start the car
What I did was hold the fob against the 10as locked then unlocked
And it started 🤷‍♂️ This could be just a coincidence but it indicates the problem is with the immobiliser I just don’t trust the car until I’ve found out what the problem is so a bit more investigation is required
Post #987685 2nd Apr 2023 9:11pm
Ianh
I agree, your issue does indicate there is an issue in the immobiliser circuit or components.
There is an antenna near the ignition switch that is connected to the 10AS, it is that antenna that communicates with the fob ( when it’s in close proximity to that antenna) to allow the fob code to be read and matched to the ones registered in the 10AS. There could be a bad connection there, so disconnecting the connectors to the 10AS , inspecting and cleaning with contact cleaner could be something to try. There could also be a bad connection in one of the connectors, so check each wire at a time to see if it’s loose.
The 10AS then communicates with the engine ECU ( also known as the PCM- Powertrain Control Module) via the IPAC on the 2.4. The dry joints on the 2.4 IPAC circuit board where the IPAC connector is soldered are a know problem that can be intermittent so I’m more inclined to think it’s the IPAC, but worth checking the 10AS connectors first.
Then next time it does not start, remove IPAC, bridge pins 3 and 4 and if it then starts you know it’s an IPAC issue. If not you have discounted the IPAC as the cause.
Post #987693 2nd Apr 2023 9:32pm
Greg H
It’s all making sense
I’ll do some digging tonight and find that control
Many thanks
Post #987714 3rd Apr 2023 9:42am
