![]() | Home > Td5 > Mileage display & electric windows switches illuminated |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Mileage display is normal to illuminate with ignition (but rest of speedo will only illuminate with lights).
Window switches shouldnt illuminate with ignition though. Pin 6 on them should be red/orange wire which is the illumination amd fed from the sidelight circuit with all of the other switches. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Some/many/most aftermarket lift switches illuminate when the ignition is on and the lift system is live.
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
Not normal. According to the wiring diagram the switches have a bulb that is illuminated with the side light circuit on a red/orange wire. Have you checked the supplies with a meter? Are the switches genuine?
![]() Click image to enlarge ![]() Click image to enlarge |
When you say "aftermarket" do you mean someone has retrofitted genuine Landrover parts to recreate a factory installation, or do you mean an aftermarket proprietary lift kit has been fitted? Without knowing this it is hard to offer useful advice, but if it is the former than I would not expect the lift switches to be illuminated when the ignition is on and if the latter than I probably would. |
FD7 Member Since: 16 Feb 2021 Location: Midland Posts: 187 ![]() ![]() |
Thanks for the replies all
![]() Yes sorry should have said the invoices are from Masai, so it's a non genuine kit, if I recall an Italian supplier so no original parts used. The buttons are non-genuine, as it differs to original TD5 slightly (touch / feel / logo etc). I've not checked anything myself as of yet with regards supplies. |
