![]() | Home > In Car Electronics > How do you use your Ultragauge? |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Hello folks,
I've just picked up one of these little gadgets and had the briefest of plays with it yesterday. They've obviously been around for a while and they're mentioned in numerous posts across the forum but I thought I'd try and distill the collective experience in one thread. So, to that end, how do people use their Ultragauges? For example, which combination of individual gauges to you find most useful, day to day? Where and how have you got it mounted and what have you done with the cable? Any other tips and tricks to get the best out of them? Any problems? Looking forward to your replies 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Interesting. Why do you want to see those values, in particular? The EGR value seems odd if you know that it'll always be zero. Darren
I was hoping for a better response to this
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781
I had a play with one for a few weeks - ended up sacking it off. Rgds.
Chris |
| Jem_90 Member Since: 10 May 2019 Location: Oxon Posts: 54
I use the ScanGauge permanently fitted, to display Boost MAP, Oil Temp, MPG, Intake air temp.
I chose it because it was discrete, can be fitted around the steering wheel cowling & I have the ability to read/clear error codes if they pop up. Either option adds useful metrics from the puma ECU. Good luck mate |
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 610
I'm building my own Scangauge thingy based on Arduino.
Current thinking is that it will show: Battery voltage, engine temp, ambient temp, EGT, DPF load, EGR. |
