Home > Technical > 300 TDI 10as immobilizer removal |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
There is a factory supplied plug in unit to remove the spider unit which is what usually causes the problems.
It's mounted in the battery box. drill out some rivets and you can access it. Mine used to play up, I took it out and there were lots of dry solder joints on the plug. re-soldered it and it was faultless after that. |
26th Mar 2023 8:27am |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
A car I’m working on now has an immobiliser, and I’ve bought the factory bypass plug.
But if you’re “over there” and getting the plug will take a while, I know I also read something at the time I was researching this about which wires to bypass. It might give you a short term fix while waiting for the plug to arrive - which is not expensive, and makes the job a lot neater. I’d PM if I’d kept that info, or where I found it, but once a realised a plug was easily available I’m afraid I didn’t make a note. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
26th Mar 2023 10:02am |
Darren Member Since: 25 Mar 2023 Location: Arkansas Posts: 2 |
Do you have a link to the factory plug option?
26th Mar 2023 6:32pm |
Honestly, a Google for “300Tdi immobiliser bypass” will do the job. On this side of the pond it throws up lots of results. Donald
26th Mar 2023 7:40pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 487 |
AMR4956 Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
27th Mar 2023 4:49pm |
