Home > General & Technical (L663) > 4WD system question
lightning
4WD system question
Along with most people l leave my Defender in the default settings when driving on road.
Today l reversed on to a muddy field to turn around, only the rear wheels were on the field, the front wheels were on solid ground.
When l came to drive away the Defender didn't want to move, the rear wheels spun and it barely moved forward.
l thought that drive would be shifted to the front wheels.
Do l need to set one of the off road modes to get the 4WD working in this way? Te me it looked like it was in RWD
Post #986403 22nd Mar 2023 2:11pm
graemesmith1960
Sounds faulty to me.
I had to reverse up a steep road that was basically sheet ice a few months ago (driver coming up the hill in his van got stuck and slid back down and blocked the road). The 4WD worked flawlessly basically turning one wheel at a time without any interaction from me. I left it in Comfort Mode (I don't have Auto Terrain Response) as it was pitch black, I was late for a flight and couldn't remember how to get Low Traction Launch or any other fancy stuff! I learned my lesson and a couple of days later spent a good couple of hours selecting different programs and in and out of low ratio until I could do it all without having to think and stare at the screen.
When I did the Landrover Experience Day in the Defender we spent most of it on Low Ratio but everything just worked. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
Post #986414 22nd Mar 2023 4:53pm
lightning
The vehicle has only done 3,000 miles. l am not sure if there's any way to test it, there's no warnings on the dash.
If it was only in 2WD wouldn't you get the warning come up?
How could l test the 4WD? Perhaps l need to find another muddy field!
Post #986440 22nd Mar 2023 8:55pm
steam_simon
I'm no expert but there is a diff lock between the front and rear axles as standard. If you bring up 4WD in the IDD it will show whether this is locked or not. I suspect that in Comfort it is only unlocked and therefore the rear wheels will spin. If you had selected an off-road mode, then diff lock should have allowed the power to go to the front wheels (I think!).
Post #986442 22nd Mar 2023 9:11pm
lightning
You could well be correct.
l'll try it again tomorrow, there's a local farmer that l know, will let me on his land. l will report back when l've tried it out.
Post #986453 22nd Mar 2023 10:21pm
GreenMonster
United States
The center locker works in comfort mode. If it’s anything, it’s not that. Even if it didn’t lock, TC would kick in after the wheels slip.
Post #986869 26th Mar 2023 1:14pm
lightning
l've not tested it yet. l'll report back when l can get on to a muddy field with it.
Post #986920 26th Mar 2023 7:43pm
J77
Yes you definitely get a warning, my 90 had issues with 2WD warnings popping up on the dash, though it was in 4WD. 24MY 90 D250 HSE, Tasman Blue
Post #986932 26th Mar 2023 8:34pm
